Итак, есть совсем простенькая нода на NRF52832 (Е73 от EBYTE), по команде с контроллера тыкает домофон (параллельно кнопке выхода) через оптрон. Питается от домофона же через DC DC (нормальный народный 5-24 в 3.3 от не самого дохлого бренда WAVGAT)
Скетч скопипазжен со стандартного с незначительными изменениями:
//#define RF24_CHANNEL 76 //RF channel for the sensor net, 0-127
//#define RF24_DATARATE RF24_250KBPS //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
//#define RF24_PA_LEVEL RF24_PA_LOW //Sensor PA Level == RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBM, and RF24_PA_MAX=0dBm
//#define RF24_PA_LEVEL_GW RF24_PA_LOW //Gateway PA Level, defaults to Sensor net PA Level. Tune here if using an amplified nRF2401+ in your gateway.
//#define BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL) // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
#define MY_NODE_ID 10
//#define MY_RADIO_RF24
//#define MY_RADIO_RFM95
//#define MY_RF24_CE_PIN 10
//#define MY_RF24_CS_PIN 9
// Enable repeater functionality for this node
#define MY_REPEATER_FEATURE
//#define MY_WITH_LEDS_BLINKING_INVERSE
// Set blinking period
//#define MY_DEFAULT_LED_BLINK_PERIOD 300
// Flash leds on rx/tx/err
// Uncomment to override default HW configurations
#define MY_DEFAULT_ERR_LED_PIN 8 // Error led pin
#define MY_DEFAULT_RX_LED_PIN 5// Receive led pin
#define MY_DEFAULT_TX_LED_PIN 11// Transmit led pin
#define RELAY_PIN 25 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
#define RELAY_ON LOW // GPIO value to write to turn on attached relay
#define RELAY_OFF HIGH // GPIO value to write to turn off attached relay
#define CLICK_LONG 300 //ms
#define RELAY_AS_CHILD_SENSOR_ID 1
pinMode(RELAY_PIN, OUTPUT);
digitalWrite(RELAY_PIN, RELAY_OFF);
sendSketchInfo("ClickRelayNRF5", "1.0");
present(RELAY_AS_CHILD_SENSOR_ID, S_BINARY, "Intercom relay");
wdt_enable(WDTO_4S);
void loop(){
wait(10000);
if (!sendHeartbeat(true)) {
digitalWrite(MY_DEFAULT_ERR_LED_PIN, LOW);
digitalWrite(MY_DEFAULT_ERR_LED_PIN, HIGH);
void receive(const MyMessage& message)
// We only expect one type of message from controller. But we better check anyway.
if (message.type == V_STATUS && message.getBool()) {
// Change relay state
digitalWrite(RELAY_PIN, RELAY_ON);
CORE_DEBUG("Incoming change for sensor: %i\n", message.getBool());
wait(CLICK_LONG);
Работала без нареканий около 2х недель. Перестала подавать признаки жизни. Светодиоды не мигали, в контроллере "Offline". Передернул питание. Отработала еще 4 дня и опять. Думал попала влага или еще чего.... Снял, все проверил 10 раз , воткнул в скетч сторожевой таймер. Отработала еще 2 дня и повисла. Собака не спасла. Переткнул питание еще и снова 2 дня и зависон.
Куда рыть?
На всякий случай:
Фото готового устройства
Корпус: распредкоробка 43х43 из Леруа
Компилировал и заливал в Visual Code for Visual Studio, через J-Link
Поскольку случай самопроизвольного отвисания через 12 часов был - продолжаю бороться программными методами.
Добавил отправку причины перезагрузки и добавил софтовую перезагрузку при 20 неудачных попытках подряд отправить хеарбит (типа страховка от зависания радио).
$resetReasons = Array();
$oneReason = Array('Str' => 'from wake-up from OFF mode detected by entering into debug interface mode',
'Msk' => (1 << 18));
define(POWER_RESETREAS_DIF_Str, 'from wake-up from OFF mode detected by entering into debug interface mode');
define(POWER_RESETREAS_DIF_Pos, 18); /*!< Position of DIF field. */
define(POWER_RESETREAS_DIF_Msk, (1 << POWER_RESETREAS_DIF_Pos)); /*!< Bit mask of DIF field. */
$resetReasons[] = $oneReason;
$oneReason = Array('Str' => 'from wake-up from OFF mode detected by the use of ANADETECT signal from LPCOMP',
'Msk' => (1 << 17));
define(POWER_RESETREAS_LPCOMP_Str, 'from wake-up from OFF mode detected by the use of ANADETECT signal from LPCOMP');
define(POWER_RESETREAS_LPCOMP_Pos, 17); /*!< Position of LPCOMP field. */
define(POWER_RESETREAS_LPCOMP_Msk, (1 << POWER_RESETREAS_LPCOMP_Pos)); /*!< Bit mask of LPCOMP field. */
$oneReason = Array('Str' => 'from wake-up from OFF mode detected by the use of DETECT signal from GPIO',
'Msk' => (1 << 16));
define(POWER_RESETREAS_OFF_Str, 'from wake-up from OFF mode detected by the use of DETECT signal from GPIO');
define(POWER_RESETREAS_OFF_Pos, 16); /*!< Position of OFF field. */
define(POWER_RESETREAS_OFF_Msk, (1 << POWER_RESETREAS_OFF_Pos)); /*!< Bit mask of OFF field. */
$oneReason = Array('Str' => 'from CPU lock-up detected',
'Msk' => (1 << 3));
define(POWER_RESETREAS_LOCKUP_Str, 'from CPU lock-up detected');
define(POWER_RESETREAS_LOCKUP_Pos, 3); /*!< Position of LOCKUP field. */
define(POWER_RESETREAS_LOCKUP_Msk, (1 << POWER_RESETREAS_LOCKUP_Pos)); /*!< Bit mask of LOCKUP field. */
$oneReason = Array('Str' => 'from AIRCR.SYSRESETREQ detected',
'Msk' => (1 << 2));
define(POWER_RESETREAS_SREQ_Str, 'from AIRCR.SYSRESETREQ detected');
define(POWER_RESETREAS_SREQ_Pos, 2); /*!< Position of SREQ field. */
define(POWER_RESETREAS_SREQ_Msk, (1 << POWER_RESETREAS_SREQ_Pos)); /*!< Bit mask of SREQ field. */
$oneReason = Array('Str' => 'from watchdog detected',
'Msk' => (1 << 1));
define(POWER_RESETREAS_DOG_Str, 'from watchdog detected');
define(POWER_RESETREAS_DOG_Pos, 1); /*!< Position of DOG field. */
define(POWER_RESETREAS_DOG_Msk, (1 << POWER_RESETREAS_DOG_Pos)); /*!< Bit mask of DOG field. */
$oneReason = Array('Str' => 'from pin-reset detected',
'Msk' => 1);
define(POWER_RESETREAS_RESETPIN_Str, 'from pin-reset detected');
define(POWER_RESETREAS_RESETPIN_Pos, 0); /*!< Position of RESETPIN field. */
define(POWER_RESETREAS_RESETPIN_Msk, (1 << POWER_RESETREAS_RESETPIN_Pos)); /*!< Bit mask of RESETPIN field. */
$s = "";
foreach($resetReasons as $reason){
if (($this->getProperty('debugVar') & $reason['Msk']) > 0) {
$s.=((strlen($s) > 0? ", " : "").$reason['Str']);
if (strlen($s) == 0) $s = "power failed.";
say('Перегрузился кликер: '.$s);
